查看: 2105|回复: 5
ITS FORMAT REPOT(标准报告)
发表于 2007-12-4 11:58:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Title: Provisional Inspection Report Fo (FRI )
Form No: PIR-HKG-IT-FRI -American Eagle Outfitters          Revision No.: 09        Inspected by        :
Requirement Document No.  :                Reviewed by Senior QA Engineer or above        :
WI-REQ-HKG-IT- 228        Revision No.: ______        Checked by Administration Group        :
TO        :  American Eagle Outfitters        Report No. : _____________
ATTN.        :  Ms. Swati Kellar
        PROVISIONAL INSPECTION  REPORT
Inspection requirement:    [   ] Final Random inspection     [   ] ________  re-inspection (FRI)
Overall inspection result: [   ] Conformed    [   ] Not conformed
APPLICANT:         American Eagle Outfitters
         401 Fifth Avenue, Second Floor,
New York,
New York 10016-3317
USA,
ATTN.:
STYLE NAME  : _______________________________________________________________________________________
BUYER                :   American Eagle Outfitters
AGENT                : ______________________________________________________________________________________
SUPPLIER            : ______________________________________________________________________________________
CHARGE PARTY:  [   ] American Eagle Oufitters               [   ] Supplier
MANUFACTURER & ADDRESS :________________________________________________________________________
______________________________________________________________________________________________________
ORDER NO.        :                                         STYLE NO.                  : _______________________________
DIVISION            : ____________________________                DEPARTMENT           : _______________________________
ORDERED QUANTITY :                                           SHIPPED QUANTITY: _______________________________
DATE OF INSPECTION:                                         PLACE OF INSPECTION :  [    ] CHINA (                                  )
        [    ] MACAU  [    ] HONG KONG
INSPECTION                      Final Random Inspection against American Eagle Outfitters Requirement
REQUIREMENT:             Acceptable Quality Level (AQL) for: Critical defective :  Not allowed on the inspected samples
        Major defective        :  2.5
         The inspection results of the above mentioned merchandise were found as follows :
                 Inspection criteria                                        Result
        Quantity Available                [   ] Conformed / [   ] Not conformed, refer to the last page Special Attention point
        Product Description, Style & Colour        [   ] Conformed / [   ] No sample given/  [   ] Not conformed, refer to the last page Special Attention point _________________
        Workmanship                [   ] Conformed / [   ] Not conformed / [   ] Refer to the last page Special Attention point
Data Measurement / Check        [   ] Conformed / [   ] Not conformed
       - Size measurement        [   ] Conformed / [   ] Not conformed, refer to the last page Special Attention point ______________
       - Bar code readability        [   ] Conformed / [   ] Not conformed, refer to the last page Special Attention point ______________
       - Labelling        [   ] Conformed / [   ] Not conformed, refer to the last page Special Attention point ______________
       - Carton assortment        [   ] Conformed / [   ] Not conformed, refer to the last page Special Attention point ______________
        Form of Packaging                [   ] Conformed / [   ] Not conformed, refer to the last page Special Attention point ______________
        Shipping Mark                [   ] Conformed / [   ] Not conformed, refer to the last page Special Attention point ______________
             Factory’s representative signature and chop :        (Departure Time :                       )
INSPECTION RESULTS :
The inspection results were found as follows :
QUANTITY AVAILABLE :
        [   ]  Order
        Quantity             Lot size            Packed           quantity                Not
        Packed                Not
        Finished
        Quantity                Sample size
        [   ] requested
      Inspection
       Quantity                                          From packed quantity        From not packed quantity
No. of pcs / set
No. of pcs / set
No. of carton
No. of carton
Carton / polybag selected for sampling :        [    ] Carton number not assigned yet.
        [   ] No:
[  ]Carton / polybag sealed after inspection :
        [   ] No :
        [  ] Discrepancy was found, please refer to Special Attention on the last page .
WORKMANSHIP :
All the                           selected samples were checked and the results were found as follows :
Details of defective :
        Cr        Ma        Mi
        Found :
Accumulated finding:
Allowed :                        -----
        * 3 garments with 1 minor defect on each will treated as 1 Major defective.
SPECIAL ATTENTION :
NOTE :
        [   ]        Production sample(s) will be sent to the applicant /________________________________ on ____________________.
No. of sample        Colour        Size        Defect
        [   ]        Production sample(s) will be kept at Intertek local office waiting for further instruction from our client.
        [   ]        All the selected cartons were not sealed after inspection because the factory did not repacked them immediately.
        [   ]        This inspection does not cover the fabric quality such as the fabric strength and the seam slippage. These silk fabric is usually weak in fabric strength and seam slippage.
[   ]          This is Re-inspection for previous Inspection Report Number __________ dated __________.
        [   ]        The hand-written Provisional Inspection Report was copied to the factory.
        [   ]        Enclosed with                           pages (s) of attachments and digital photos
[   ]         Overall measurement finding:        [   ] Conformed / [   ] Not conformed
        Total points measured:
        Out of tolerance measurement points:
        AQL allowance:
        Size Measurement Chart
        (Full Measurement Points)
Style No.: __________________________     Style Name: _____________________________       Report No. : _____________
MEASUREMENT POINT        SZ                SZ                SZ                SZ                SZ                SZ                TOL
(INCH)        CL                CL                CL                CL                CL                CL
        (10% Critical Measurement Points)
MEASUREMENT POINT        SZ        SZ        TOL
(INCH)        CL        CL
PHOTO ATTACHMENT:                        Report No.: IJ __________________
File no. # _______
        File no. # _______        File no. # _______
Main Label        Care Label        Care instruction label
File no. # _______
Size label        Security tag        Bar code price tag (USA)
File no. # _______
Bar code price tag (Canada)         Shipping mark for USA(wider side)        Shipping mark for USA(narrower side)
发表于 2007-12-4 14:13:07 | 只看该作者
lz,能否上传原始的文档啊, 这个很乱哦.
发表于 2007-12-4 15:30:37 | 只看该作者
有点乱,楼主发附件好了
发表于 2007-12-23 19:00:20 | 只看该作者
确实有些乱, 有原文档就好了
发表于 2010-5-12 11:28:32 | 只看该作者
学习了 顶下
发表于 2010-5-26 10:24:57 | 只看该作者
GMT+8, 2026-11-5 06:45 , Processed in 0.315147 second(s), 19 queries , Gzip On.
