查看: 938|回复: 5
有没有验过缝纫机的?
发表于 2007-11-30 12:54:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
主要做什么测试?
一般要记录哪些参数?
发表于 2007-11-30 15:24:53 | 只看该作者
电动的还是脚踏的?
 楼主| 发表于 2007-11-30 16:05:33 | 只看该作者
电动的
以前从来没接触过
发表于 2007-11-30 19:42:18 | 只看该作者
我验过:主要附件不要少1 Sewing machine
1 Foot control
1 Instruction manual
1 warranty card
Standard accessories
a.All purpose foot
b.Zipper foot
c.Buttonhole foot
d.Button sewing foot
e.L-screwdriver
f.Seam ripper/ brush
g.Oil bottle
h.Spool holder (Large)
i.Pack of needles (3x)
j.Seam guide
k.Bobbin (3x)
l.Darning plate
m.Cover
发表于 2007-11-30 19:43:37 | 只看该作者
Components check list
Parts name        Actual found:
Power Plug        YY-2 AC125V, 10A E246509(not conformed spec:E137398)
Power cord        SPT-2 18AWGX2C E246509(not conformed spec:E137357)
Power Switch        RL3 AC120V. 6AT125℃ E208316
Foot controller        KD-1902 AC110-120V 0.95A E220504
Appliance inlet        Z11 AC125C 3A E233507
Inlet connector        W11 AC125V 3A E233504
Motor        HF-07150 AC110-120V 50/60Hz 0.62A 70W E238574
Lampholder        SB-E12 AC125V 75W E187950
Internal tube        CFT-600VW-1 PVC 105℃ E152385 CHERN FWVH LB77878 CSA 105℃(not conformed spec)
Internal wire        UL E189672 SPT-1 18AWGX2c vw-1 105℃ 300v, CSA LL213732 SPT-1 18AWGX2c
FT2 105℃ 300v not conformed spec)
Enclosure materilal        1000 94HB 600C
把这些对清楚
发表于 2007-11-30 19:45:15 | 只看该作者
Function and assembly test. - Pls check that the product works correctly.
Check all functions. Use as reference the instruction manual.
Zigzag stitching, Blind hem/ lingerie stitch, Overlock stitches,Sewing on buttons, Zippers and piping, 3-step zig-zag, etc
The inspector must verify the function requested by the client. - Multi-function sewing machine, 18 stitch function plus 4 step button-hole, foot controller, standard accessories, foldable handle.
GMT+8, 2026-10-22 03:51 , Processed in 0.130774 second(s), 19 queries , Gzip On.
