查看: 810|回复: 6
爬电距是怎样测的?
发表于 2007-11-29 20:23:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
爬电距是怎样测的?
发表于 2007-11-29 21:18:02 | 只看该作者
正极与负极没有经过任何负载(如电阻)的最短距离.
发表于 2007-11-29 23:14:59 | 只看该作者
L.2 When measuring creepage distances, the following applies.
The working voltage, pollution degree and material group are determined.
The creepage distances of basic insulation and supplementary insulation are measured
and compared with the minimum values specified in table 17. A particular creepage distance
is then compared with the corresponding clearance of table 16 and enlarged if necessary in
order not to be less than the clearance. For pollution degree 1, the reduced clearance based
on the impulse voltage test can be used. However, the creepage distance can not be less
than the values of table 17.
The creepage distances of functional insulation are measured and compared with the
minimum values specified in table 18.
The creepage distances of reinforced insulation are measured and compared with twice
发表于 2007-11-29 23:18:12 | 只看该作者
一句话,就是两极之间的沿表面的距离.
发表于 2007-11-30 22:20:34 | 只看该作者
"沿表面"不是很清楚.
还是下面的好.
正极与负极(即两极)没有经过任何负载(如电阻)的最短距离.
 楼主| 发表于 2007-12-1 13:12:30 | 只看该作者
回复 #3 Love1974 的帖子
undefined ,THANKS!
 楼主| 发表于 2007-12-1 13:13:35 | 只看该作者
回复 #5 crazystandard 的帖子
undefined ,thanks!
GMT+8, 2026-1-30 16:41 , Processed in 0.045591 second(s), 18 queries , Gzip On.
