查看: 4706|回复: 31
内衣厂常用英语(共享)
发表于 2007-11-22 16:08:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
中文
英文
A
1/2腰圍(放鬆度)
1/2 Waist length (relaxed)
Waist on half
1/2 Elasticatied waist
1/2腰圍平度
Waist flat on half
A1
1/2腰圍(拉度)
1/2 Waist elastic strength
1/2 Front waist elastic strength
Waist stretch
Waist extended
Waist min stretch
A2
1/2腳圍(下腳闊)
1/2 Bottom width
A3
坐圍
Hip circle at top of leg
Hip across top of leg
坐圍彎度
1/2 Hip (folded meas.)
B
1/2脾圍不計側繩
1/2 Thigh length excl. side elastic (side string)
1/2脾圍
1/2 Thigh (edge to edge)
Leg on half
Leg opening 1/2
1/2脾圍放鬆度
Leg flat - relaxed on 1/2
1/2脾圍放鬆度
1/2 Leg circumference
1/2脾圍拉度
Leg extended on 1/2
1/2脾圍拉度
Leg stretch
1/2脾圍(直度)
Leg drop (straight line)
1/2脾圍穿起計右邊,放鬆度
1/2 Thigh length band - right side worn,relaxed
 楼主| 发表于 2007-11-22 16:09:13 | 只看该作者
脾圍
Leg circle
脾圍放鬆度
Leghole relaxed
脾圍不連側繩
Thigh length (excl. waistband)
前幅褲脾長
Front leg length
前花邊長
Front EMB leg
前幅褲腳長連浪
Front leg flat incl. gusset
前褲腳長至骨位穿起計左邊
Back thigh length to seam - left side worn
後褲腳長至骨位穿起計左邊
Front thigh length to seam - left side worn
C
前中長彎度至花邊牙底
Front height - fold along edge / low scallop
前中長彎度(包褲頭丈巾)
Front height - fold along edge (incl. Waistband)
Frontlength incl. WB
前中長(彎度,連綑條)(連浪)
Front height (curved,incl. binding)(incl. Crotch)
前中連底浪
Front length + Gusset length
前中長至前浪
C/F rise to front gusset
前中彎度
Centre front length (curve measured)
Front rise cf to back gusset seam
Front rise (folded meas.)
前中長包褲頭巾
CF to gusset (incl. W/B)
 楼主| 发表于 2007-11-22 16:10:32 | 只看该作者
D
後中長變度
Back height - fold along edge
Back rise including waist band
Back rise (folded meas.)
後中長包褲頭巾
CB to gusset (incl. W/B)
後中長(彎度,連綑條)
Back height (cureved,incl. binding)
後中長至前浪
Back rise to front gusset
後中長平度
Back centre length (plane)
後中丈巾長
Back string length cut at
後繩長(不連吊飾)
Back length (excl. motif)
E
前浪闊
Front gusset width
前浪闊-沿骨度(連丈巾)
Front crotch width - along seam (incl. Elastic)
前浪骨闊(連丈巾)
Front crotch seam width (incl. Elastic)
前浪闊(後浪骨上10cm處)
Front crotch width (10cm up from back crotch seam)
前浪闊(浪骨上11.5cm處)
Front seat width (11.5cm up from crotch seam)
Measure 11.5cm up from gusset
前浪闊褲頭落15cm處
Gusset width front 15cm fr to
前幅褲頭落11cm處
Across front 11cm fr to
 楼主| 发表于 2007-11-22 16:12:30 | 只看该作者
F
後浪闊
Back gusset width
後浪闊-沿骨度(連丈巾)
Back crotch width - along seam (incl. Elastic)
浪闊(度最窄位)
Gusset width - narrowest
後幅闊浪上12cm處度
Back width 12cm abv gusset
後帶距(後幅最窄位)
String width back
褲頭至後帶距長
Length to string
G
底浪長彎度
Crotch length - fold along edge
浪長
Gusset length
H
側骨
Side height / side depth
Side height depth
Sideseam fr. Upper edge
側骨包褲頭巾&綑條
Side length (incl. W/B & trim)
 楼主| 发表于 2007-11-22 16:14:12 | 只看该作者
前幅褲頭長
Front panel width
前幅褲頭長(不連側繩)
Front waist width (excl. side rope)
後幅褲頭長
Back panel width
褲頭繩長(打結後)
Waist string length (after knots)
側繩長
Side waistband length / side string length
Side rope length
兩側位丈巾長
Length of side rouleaus cut at
側丈巾帶長
Tanga sides finished
側繩長7cm回帶後
Side elastic length w/7cm loop
前側繩長(綁帶)
Front side string length
後側繩長(綁帶)
Back side string length
褲側綁帶長
Side strap length
前帶長(穿起計左邊)
Front belt length (left side as worn)
前帶長(穿起計右邊)
Front belt length (right side as worn)
前腰帶長
Front belt length
前三角闊
Front triangle width
前三角高
Front triangle height
綑邊丈巾闊
Foldover binding width
参与人数 1金币 +15 威望 +40 收起 理由
celiahe + 15 + 40 你太有才了
发表于 2007-12-26 12:29:11 | 只看该作者
Well Done
发表于 2007-12-26 18:04:00 | 只看该作者
对我比较有用哈
发表于 2007-12-29 18:54:39 | 只看该作者
好东西,能学习,够用,感谢
发表于 2007-12-30 12:22:42 | 只看该作者
不好保存啊, 要是纯文本格式就好啦
发表于 2008-1-19 00:31:38 | 只看该作者
不错,是个好东西,同行
GMT+8, 2026-11-4 11:11 , Processed in 0.035398 second(s), 18 queries , Gzip On.
