查看: 825|回复: 2
阀门英汉术语对照
发表于 2007-11-22 12:38:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Air valves 空气阀门
     Angle Stop valves 角式截止阀
     Angle Throttle Valves 角式节流阀
     Angle Type Globe Valves 门角式截止阀
     Ash valves 排灰阀
     Aspirating valves 吸(抽)气阀
     Auxiliary valves 辅助(副)阀
     Balance valves 平衡阀
     Bellows valves 波纹管阀
     Blowdown valves 泄料(放空,排污)阀
     Brake valves 制动阀
     Butterfly Type Non-slam Check 蝶式缓冲止回阀
     Butterfly Valves with Gear Actuator 蜗轮传动蝶阀
     Buttwelding valves 对焊连接阀
     Clamp valves 对夹式阀门
     Cock 二通
     Combination valves 组合阀
     CQ Thread Ball Valves CQ螺纹球阀
     Culvert valves 地下管道阀
     Deceleration valves 减速阀
     Diaphragm Valves 隔膜阀
     Decompression valves 泄压阀
     Double Disc Flat Gate Valves 双闸板平板闸阀
     Double Disk Parallel Gate Valves明杆平行式双闸板闸板
     Double Opening Exhaust Valves 双口排气球
     Drainage valves 排水阀
     Electric Actuated Stop Valves 电动截止阀
     Electric Actuated Wedge Gate Valves电动楔式闸阀
     Electric Double Disk Parallel Gate Valves电动平行式双闸板闸板
     Emergeny Cut-off Valves 紧急切断阀
     Exhaust valves 排气阀
     Free Float Type Steam Trap 浮球式疏水阀
     Flange Ball Valves 法兰球阀
     Flange Gate Valves 法兰闸阀
     Flange Globe Valves 法兰截止阀
     Gauge Valves 仪表阀
     Hand-operated valves 手动阀
     Hard Seal Butterfly Valves 金属密封碟阀
     High Temperature Pressure Power Station Gate Valves 高温高压电站闸阀
     High Temperature Pressure Power Station Globe Valves 高温高压电站截止阀
     Hydraulic relay valves 液压继动阀
     Lift Check Valves 升降式止回阀
     Limit valves 限位阀
     Lining Ball Valves 衬里球阀
     Lining Butterfly Valves 衬里碟阀
     Lining Check Valves 衬里止回阀
     Lining Cock 衬里二通
     Lining Globe Valves 衬里截止阀
     Lining T-Cock Valves 衬里三通旋塞阀
     Liquid Indicator 液位计
     LPG Pipe Fitting 液化气管件
     Magnetic Co-operate Globe Valves磁耦合截止阀
     Magnetism Forle Pumps 磁力泵
     Manual Oil Pumps Valves 手摇油泵(阀)
     Meter Needle Type Globe Valves 仪表针形截止阀
     Oblique Stop Valves 直流式截止阀
     Parallel Slide Valves 浆液阀
     Pintle valve 针形阀
     Piping Centrifugal Pumps 管道离心泵
     Plunger valves 柱塞阀
     Pressure valve 压力(増压)阀
     Piping Pumps 管道泵
     Piping Safety Valves 管道安全阀
     Plunger Globe Valves 柱塞截止阀
     Quick Draining Valves 快速排污阀
     Restrictor Valves 过流阀(或节流阀)
     Safety Valves 安全阀
     Screw Pumps 螺杆泵
     Scum Gate Valves 排渣闸阀
    Solenoid valves 电磁阀
     Single Disc Flat Gate Valves 单闸板平板闸阀
     Single Opening Exhaust Valves 单口排气球
     Slurry Pumps 泥浆泵
     Stop Valves 截止阀
     Strainer 过滤器
     Submerged Motor Pumps 潜水电泵(排污泵)
     Swing Check Valves 旋启式止回阀
     Tank Lorry Ball Valves 槽车球阀
     T-Cock 三通
     Thin Gate Valves 薄型闸阀
     Throttle Valves 节流阀
     Tiny Drag Slow Shut Check Valves 微阻缓闭止回阀
     Triple (tee) valves 三通阀
     Two-way valves 二通阀
     Under Water Pumps 液下泵
     Vacuum Pumps 水力喷射器(真空泵)
     Vertical Lift Check Valves 立式止回阀
     Wafer Check Valves 对夹式止回阀
     Wafer plate valves 对夹蝶板阀
     Wafer Type Butterfly Valves with Rubber Itning对夹式衬胶蝶阀
     Waste Valves 排污箱(阀)
     Water Seal Gate Valves 水封闸阀
     Wedge Gate Valves 楔式闸阀
     Y Type and Cylinder Filters Y型筒型过滤器
     阀门零部件英汉术语对照
     Axis Guide 轴套
     Ball 球、球芯
     Ball seat 密封圈
     Blowdown Sealing Face 启、阀件密封面
     Body 阀体
     Bonnet 阀盖
     Disc 阀瓣
     Mut 螺母
     Screw 螺栓
     Sealing 密封件
     Spring 弹簧
     Stem 阀杆
     Stem Mut 阀杆螺母
     Stem seal 填料
     Wedge Disc 闸板
     阀门规范技术英语术语对照
     Applicable medium 适用介质
     Applicable temperature 适用温度
     Butt Clamp 对夹
     Chemical analysis 化学成份
     Connecting format 连接形式
     Double disc 双闸板
     Flexible disc 弹性闸板
     Flange 法兰 Hoop 卡箍
     Inside thread 内螺纹
     Jacket 夹套
     Mains 电源
     Material chemical analysis and mechanical capacity材料化学成份和机械性能
     materials 材料 Materials for main parts 主要零件材料
     Mechanical capacity 机械性能
     Max. Discharging Capacity 最大排水量
     Max. Operating Temperature 最高工作温度
     Max. Allowable Temperature 最高允许温度
     Max. Allowable Pressure 最高允许压力
     Model 型号
     Name of parts 零件名称
     nitrogen (N) 氮
     Nominal bore 公称通径
     Nominal Pressure 公称压力
     Nozzle 排气口
     Outside thread 外螺纹
     Oxidant 氧化性介质
    Parallel 平行
     Piping 管路
     Piston 活塞
     Reductant 还原性介质
     Rising stem 明杆
     Seal 阀座,密封面
     Seat testing pressure 压力气密封试验压力
     Socket 卡套
     Specifications 性能规范
     Single disc 单闸板
     Solid 刚性
     Strengh testing pressure 强度试验压力
     Steam , condensate 蒸汽,凝结水
     Stroke 冲程,行程
     Water,oil,steam 水,温度,气
     Wedge 楔式 Welding 焊接
     阀门材质术语英汉对照
     Atbas metal 镍铬钢
     Buna-N rubber 丁晴橡胶
     Casting aluminium brass 铸铝黄铜
     Casting aluminium bronze 铸铝青铜
     Ceramic metal 陶瓷金属
     Chromel alloy 镍铬合金
     CHR rubber 氯晴橡胶
     Chrominm-molybdenum-vanadium steel 铬钼钒钢
     Chromium stainless steel 铬不锈钢
     Chromium-molybdenum steel 铬钼钢
     Corrugation pad 波形垫
     Cuprum alloy 铜合金
     Ductile Cast iron 球墨铸铁
     Expanded graphite 柔性石墨
     Fine Steel Casting iron 优质碳素钢
     Fluorous rubber 氟橡胶
     Gray Cast iron 灰铸铁
     Hayne's alloy 钴铬钨合金
     High tem perature steel 高温钢
     Monel 蒙乃尔合金
     Low temperature steel 低温钢
     Nylon 尼龙塑料
     Polytetrafluoroethylene(PTEF) 聚四氟乙烯
     Polythene 聚乙烯
     Pure aluminium 纯铝
     Pure cupper 纯铜
     Rubber graphite board 橡胶石墨板
     Spring steel 弹簧钢
     Stainless acid-resisting steel 不锈耐酸钢
     Stainless and Graphite 不锈钢/石墨
     Stainless steel 不锈钢
     Steel Casting iron 碳素钢铸件
     Shell Test Pressure 壳体试验压力
     Service Fluid 工作介质
发表于 2007-11-22 18:16:10 | 只看该作者
LZ真是大好人啊......谢谢LZ...
发表于 2008-11-29 16:40:36 | 只看该作者
学习了.感谢楼主!!
GMT+8, 2026-11-30 16:44 , Processed in 0.026291 second(s), 18 queries , Gzip On.
