楼主: HoCheung
To improve English
71#
发表于 2008-4-12 18:57:06 | 只看该作者
In accordance with my experience, i think that listening is the first ,and speaking is the second .You must train your sense of language in english . That is most important if you want to be fluent in oral english
参与人数 1金币 +2 威望 +2 收起 理由
HoCheung + 2 + 2 我很赞同
72#
发表于 2008-4-12 18:59:46 | 只看该作者
If you spent one hour in speaking english every day . After two or three years your oral english would be fluent or  excellent.
73#
发表于 2008-4-15 11:59:35 | 只看该作者
Thanks, I agree
74#
发表于 2008-4-18 17:33:42 | 只看该作者
practice,practice and keep pracitce,it is the basic qualification to enhence the english level.
75#
 楼主| 发表于 2008-4-18 17:55:57 | 只看该作者
回复 #62 星夜 的帖子
haha, a little.....
76#
发表于 2008-4-21 20:25:57 | 只看该作者
回复 #9 HoCheung 的帖子
Vocabulary isn't the first thing to the learning english fans.As you know,if you recite new words  only for bearing in mind,that it get half the result with twice the effort.It is a pith by the end.We would accomplish nothing.
77#
发表于 2008-4-21 20:31:43 | 只看该作者
回复 #10 dobbin 的帖子
78#
发表于 2008-4-21 20:45:12 | 只看该作者
回复 #10 dobbin 的帖子
As fas as i know , if you master hundreds of vocabulary in oral english,it would be easy and fluent to commucate with others .Please bear in mind what i said.
79#
发表于 2008-4-23 08:24:21 | 只看该作者
TO improve oral english,the best method i think is to read the english books very often& loudly so as to enhance ur sense of language,then u r able to bolt it out in the daily life.and for others u should see some foreign films or listen the qualified person's expression if any chance to get a basic frame or configuration of expression.
80#
发表于 2008-4-23 08:27:30 | 只看该作者
Here is my MSN:apple_rose555@hotmail.com
GMT+8, 2026-11-30 13:32 , Processed in 0.027936 second(s), 17 queries , Gzip On.
