查看: 841|回复: 3
求助:贸易公司电脑周边产品验货方法标准.
发表于 2007-11-3 18:05:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
电脑键盘,鼠标,耳机,等等产品的检验标准和程序,谢谢!
发表于 2007-11-3 19:18:42 | 只看该作者
HOW TO USE.HOW TO CHECK
every accessories,has its differet check way.
but in fact,they are similar.
1.cosmetic check
2.function check
3.safety regulation check.
for cosmetic check.everyone ,should know,you can check it as per the company or client's requirement.
for function.how to use,how to check.it is basic check way.For detail check way,at present,you can find,on some professional websize,there are some softwares,had been designed and supplied for their check.if you think they are used difficultly,you can find the function check way as per its using way  .
for safety regulation.PLS find out the safety regulation about you product.as per standard,check it one by one as you can do.
发表于 2007-11-4 19:39:55 | 只看该作者
good practice as well here reading
发表于 2009-3-20 23:08:23 | 只看该作者
回复 2# cancelled 的帖子
太多英文,看不懂。请译中文呀。
GMT+8, 2026-10-23 09:38 , Processed in 0.053998 second(s), 18 queries , Gzip On.
