查看: 1250|回复: 9
En 14960 Inflatable play equipment — Safety requirements and test methods
发表于 2007-10-11 17:46:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
New standard: BS EN 14960:2006
This standard is applicable to inflatable play equipment intended for use by children fourteen years and under both individually and collectively.
This standard specifies safety requirements for inflatable play equipment for which the primary activities are bouncing and sliding. It sets measures to address risks and also minimize accidents to users for those in-volved in the design, manufacture and supply of inflatable play equipment. It specifies information to be sup-plied with the equipment. The requirements have been laid down bearing in mind the risk factor based on available data.
This standard specifies the requirements that will protect a child from hazards that he or she may be unable to foresee when using the equipment as intended, or in a manner that can be reasonably anticipated.
This Standard is not applicable to inflatable water-borne play and leisure equipment, domestic inflatable toys, air-supported buildings, inflatables used solely for protection, inflatables used for rescue, or other types of in-flatable toys where the primary activity is not bouncing or sliding.
BS EN 14960.pdf
808.38 KB, 下载次数: 58, 下载积分: 金币 -1
参与人数 1金币 +5 威望 +5 收起 理由
yyfbz + 5 + 5 你太有才了
发表于 2007-10-11 21:02:28 | 只看该作者
支持一下!
 楼主| 发表于 2007-10-12 09:50:17 | 只看该作者
good job
good job from banzhu!
发表于 2007-10-12 11:08:18 | 只看该作者
好东西,大家支持一下!!!!
 楼主| 发表于 2007-10-19 20:11:56 | 只看该作者
support by myself
发表于 2007-11-26 13:34:34 | 只看该作者
有中文版嗎?
发表于 2007-11-30 14:27:01 | 只看该作者
中文的........................怎么加不上.
发表于 2007-12-1 19:08:00 | 只看该作者
Thank you very much!!!
发表于 2008-5-20 20:41:56 | 只看该作者
THANKS FOR SHAREING WITH US
发表于 2011-5-5 12:08:18 | 只看该作者
飘过。。。。。。。。。。。。。。。。。。。。。
GMT+8, 2026-10-17 11:15 , Processed in 0.030473 second(s), 23 queries , Gzip On.
