查看: 756|回复: 5
测试词汇中英文对照
发表于 2013-3-15 21:28:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
A 色牢度试验项目 COLOUR FASTNESS TESTS
皂洗牢度 washing
摩擦牢度 rubbing/crocking
汗渍牢度 perspiration
干洗牢度 drycleaning
光照牢度 light
水渍牢度 water
氯漂白 chlorine bleach spotting
非氯漂白 non-chlorine bleach
漂白 bleaching
实际洗涤(水洗一次) actual laundering (one wash)
氯化水 chlorinated water
含氯泳池水 chlorinated pool water
海水 sea-water
酸斑 acid spotting
碱斑 alkaline spotting
水斑 water spotting
有机溶剂 organic solvent
煮呢 potting
湿态光牢度 wet light
染料转移 dye transfer
热(干态) dry heat
热压 hot pressing
印花牢度 print durability
臭氧 ozone
烟熏 burnt gas fumes
由酚类引起的黄化 phenolic yellowing
唾液及汗液 saliva and perspiration
B 尺寸稳定性(缩水率)及有关试验项目(织物和成衣)
DIMENSIONAL STABILITY (SHRINKAGE) AND RELATED TESTS (FABRIC & GARMENT)
皂洗尺寸稳定性 dimensional stability to washing (washing shrinkage)
洗涤/手洗后的外观 appearance after laundering / hand wash
热尺寸稳定性 dimensional stability to heating
熨烫后外观 appearance after ironing
商业干洗稳定性 dimensional stability to commercial drycleaning (drycleaning shrinkage)
商业干洗后外观(外观保持性) appearance after commercial drycleaning (appearance retention)
蒸汽尺寸稳定性 dimensional stability to steaming
松弛及毡化 dimensional stabilty to relaxation and felting
缝纫线形稳定性 dimensional stability for sewing thread
C 强力试验项目
STRENGTH TESTS
拉伸强力 tensile strength
撕破强力 tear strength
顶破强力 bursting strength
接缝性能 seam properties
双层织物的结合强力 bonding strength of laminated fabric
涂层织物的粘合强力 adhesion strength of coated fabric
单纱强力 single thread strength
缕纱强力 lea strength
钩接强力 loop strength
纤维和纱的韧性 tenacity of fibres and yarn
D 织物机构测试项目
FABRIC CONSTRUCTION TESTS
织物密度(机织物) threads per unit length (woven fabric construction)
织物密度(针织物) stitch density (knittted fabric)
纱线支数 counts of yarn
纱线纤度(原样) denier counts as received
织物幅宽 fabric width
织物克重 fabric weight
针织物线圈长度 loop length of knitted fabric
纱线卷曲或织缩率 crimp or take-up of yarn
割绒种类 type of cut pile
织造种类 type of weave
梭织物纬向歪斜度 distortion in bowed and skewed fabrics (report as received and after one wash)
圈长比 terry to ground ratio
织物厚度 fabric thickness
E 成分和其他分析试验项目
COMPOSITION AND OTHER ANALYTICAL TESTS
纤维成分 fibre composition
染料识别 dyestuff identification
靛蓝染料纯度 purity of indigo
含水率 moisture content
可萃取物质 extractable matter
填充料和杂质含量 filling and foreign matter content
淀粉含量 starch content
甲醛含量 formaldehyde content
甲醛树脂 presence of formaldehyde resin
棉丝光度 mercerisation in cotton
PH值 PH value
水能性 absorbance F 可燃性试验项目
FLAMMABILITY TESTS
普通织物的燃烧性能 flammability of general clothing textiles
布料的燃烧速率(45。角) burning rate of cloth (45。angle)
瑞典成衣燃烧性能 Sweden fire properties of apparel textile
G 织物性能试验项目
FABRIC FERFORMANCE TESTS
耐磨性 abrasion resistance
抗起毛起球性 pilling resistance
拒水性 water repellency
抗水性 water resistance
折痕回复力 wrinkle recovery
布料硬挺度 fabric stiffness
弹性及回复力 stretch & recovery
H 羽绒试验项目
FEATHER & DOWN THERMAL TESTS
羽绒成分分析 composition analysis
膨松度 filling power
杂色毛和绒的比例 black tip
填充料的净重量 new weight (conditioned) of filling material
溶剂可溶物的测定 determination of solvent solube
酸度 acidity
好氧指数 oxygen number
清洁度 turbidity test
羽绒布防漏性 penetration resistance of cloth to feather & down
I 成衣附件试验项目
GARMENT ACCESSORY TESTS (LACE, ZIPPER, BUTTON, BUCKLE, ETC.)
洗涤后外观 appearanc after laundering
贮存后外观 appearance after storage
耐烫性能 resistance to ironing
拉链强力 zipper strength
拉链的往复性 reciprocating test
拉链耐用性 durability of zipper
拉链的使用性能 operability of zipper
魔术贴剪力 shear strength of hooks & loops fastener (velcro tape)
魔术贴撕离力 peeling strength of hooks & loops fastener (velcro tape)
魔术贴分合 consecutive adhere/ separation exercising on hooks & loops fastener (velcro tape)
金属抛光物的锈蚀/变色试验 corrosion / tarnish test on metallic finishes
按钮分开强力 unsnapping og snap fasteners
金属钮扣、铆钮的紧固试验 security of metallics buttons, rivets, ets.
按钮的紧固试验 security of snap button
钮扣强力 strength of buttons
耐洗液腐蚀性 resistance to wash liquor
耐干洗溶剂腐蚀性 resistance to drycleaning solvents
钮扣撞击测试 button impact test
钮扣拉力试验 button tension test
钮扣钮力试验 button torque test
按钮附着力 snap attachment strength
装饰物附着力 trim attachment strength
J 其他纺织品测试项目
OTHER TEXTILE TESTS
适当试验后推荐护理标签 care instruction/label recommendation after appropriate testing (testing charges excluded)
成衣尺寸测量 garment size measurement
硫化染料染色的纺织品的加速老化 accelerated ageing of sulphur-dyed textiles
色差判定 colour difference assessment
K 纤维和纱的试验项目
FIBRE & TESTS
短纤维长度 fibre staple length
线形密度 linear density
纤维直径 fibre diameter
单根纤维强力 single fibre strength
纤维韧性 tenacity of fibre
纱支 yarn count
纱线纤度(原样) denier count as received
连续或非连续纤维的识别 identification of continuous/ discontinuous fibres
每卷经纱长 length of thread per roll
纱线净重 net weight of thread
绞纱强力 lea strength
线圈强力 loop strength
纱线韧性 tenacity of yarn
纱捻度 twist per unit
L 填充棉试验
BATTING TESTS
重量 weight
厚度 thickness
纤维含量 fibre content
树脂含量 resin content
压缩与回复试验 compresssion and resilience test
样品分析前准备 sample dissection for analysis preparation
机洗/水洗后的外观 appearance after laundering / hand wash
M 地毯试验项目
CARPET TESTS
摩擦色牢度 colour fastness to rubbing
光照色牢度 colour fastness to light
水渍色牢度 colour fastness to water
毛束联结牢度 tuft withdrawal force (tuft bind)
毛束经密度 pitches per unit length
毛束纬密度 rows per unit length
底布密度 threads per unit length of backing
单位面积重量 weight per unit area
表面毛绒密度(只做单层毛毯) surface pile density (single level pile carpet only)
起绒纱股数 ply of pile yarn
毛绒或毛圈长度 pile or loop length
毛绒或底部的纤维成分 fibre composition of pile & back
 楼主| 发表于 2013-3-15 21:29:20 | 只看该作者
标示中英文文对照 一、干洗 Dry Cleaning 一般干洗 dryclean 专业干洗 Professionally Dryclean 商业干洗 Commercially Dryclean 以干洗为最佳 Drycleanning Recommened 短干洗周期 Short Cycle 干洗剂抽脱时间最短 Minimum Extraction 低水分 Reduced or Low Moisture 干洗过程中不可加水分 No water In System 不可用蒸汽 No Steam 二、水洗 Washing 可机洗 Machine Washable 不可水洗 Do not Wash 不可商业洗涤 Do not have Commercially Launder 可用家庭式洗涤 Home Launder 手洗 Hand Wash 手洗不可搓压 Hand Wash do not Rub 冷水洗 Cold Wash 温水洗 Warm Wash 热水洗 Hot Wash 不可水煮 Do not Boil 少洗衣量 Small Load 温和洗衣程序 Delicate/Gentle Cycle 持久压力程序 Durable Press Cycle /Permanent 分开洗涤 Wash Separately 可与类似色衣物同时洗涤 With Like Color 与深色衣物分开洗涤 Wash Dark Color Separetely 翻出底面洗涤 Wash Inside Out 不可拧干 No Wring/ Do not Wring 不可拧绞 No Twist/ Do not Twist 温水清洗 Warm Rinse 冷水清洗 Cold Rinse 彻底清洗 Rinse Thoroughly 不可脱水 No Spin/ Do not Spin 普通旋转速度脱水 Normal Spin 较短较慢程序脱水 Reduced Spin 不可浸泡 Do not Soak 只可用皂片 Use Pure Soap Flake only 只可抹洗或擦洗 Damp Wipe only 三、漂白 Bleaching 需要时漂白 Bleaching when Needed 不可漂白 No bleach / Do not Bleach 只可用非氯性漂白剂 Only Non-Chlorine Bleach 四、干衣 Drying 滴干 Drip Dry 挂干 Line Dry 荫凉挂干 Line Dry in Shade 避热挂干 Line Dry away from Heat 用烘干机烘干 Tumble Dry 用烘干机中温烘干 Tumble Warm 用烘干机低温烘干 Tumble Cool 平铺晒干 Flat Dry 定位干衣 Block to Dry 用蒸汽烘干 Steam Dry 不用蒸汽 No Steam / Do not Steam 风柜吹干 Cabinet Dry Cool 五、熨烫 Ironing and Pressing 热烫 Hot Iron 温烫 Warm Iron 低温烫 Cold Iron 不可熨 Do not Iron 反面熨 Iron on Wrong Side 用蒸汽熨烫 Steam Press/Iron 在湿润时熨烫 Iron Damp 用布间隔熨烫 Use Press Cloth 外包装 bale 箱 carton 件 package 色号 colour number 花号 design number 批号 lot number 唛头 marks 装箱单 packing list 漏验 omisson of examination 漏验率 percentage of omisson of examination 复验 re-inspection 索赔 claim indemnity 毛重 gross weight 净重 net weight 外观质量 appearance quality 内在质量 inherent quality 外观疵点 appearance 技术要求 technical requirement 感观检验 subjective inspection 取样 samoling 品质检验单 inspection certificate for quality 检验证书 inspection certificate 织物重量 fabric weight 断裂强力 breaking strength 断裂强度 breaking tenacity 缝纫强力 seam strength 染色牢度 colour fasteness 耐日晒色牢度 colour fasteness to sunlight 耐磨擦色牢度 colour fasteness to rubbing 汁渍色牢度 colour fasteness to perspiration 耐熨烫色牢度 colour fasteness to ironing 耐干洗色牢度 colour fasteness to dry cleaning 灰色样卡 grey scale 沾色样卡 grey scale for staining 纤维含量 fibre content 释放甲醛含量 releasable for maldehyde content 防蛀性 insect resistance 防污性 soil resistance 防雨性 rain proofness 织物厚度 fabric thickness 透气性 air permeability 色差 chromatic difference
 楼主| 发表于 2013-3-16 11:42:10 | 只看该作者
直接发,又没人回复一下了。。。
发表于 2013-3-16 12:36:27 | 只看该作者
thanks for your sharing
发表于 2013-3-16 21:40:43 | 只看该作者
发表于 2013-3-17 13:56:03 | 只看该作者
非常感谢
GMT+8, 2026-11-5 07:03 , Processed in 0.077587 second(s), 19 queries , Gzip On.
