查看: 2890|回复: 16
toys inspection on site test
发表于 2007-6-23 22:46:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Toys inspection on site test
1.
Small part/small ball:
2.
Small part warning: 3 years up to 6 years
Small ball warning: 3 years up to 8 years
3.
Sharp point
4.
Sharp edge
5.
Rigid Projections (under 8 years)
Applicable: both before and after abuse testing
Only vertical or nearly vertical projections are required to be evaluated
Do not apply corners of structures
6.
Circular Holes in Rigid Materials: 5 years or less
Thickness: <0.062in.(1.58mm)
Depth: 3/8in.(10mm)
admit &frac14;in.(6mm) ~1/2in.(13mm)
(Rigid materials: hardness exceeding 70 Shore A scale durometer)
7.
Hinge Line Clearance: 5 years or less
Moveable portion: &frac12; lbs and above
0.19in.(5mm)<gap<0.5in(13mm)
8.
Surface coating (adhesion test)
1/16 inch,
make 9 straight parallel cuts
135 degrees
9.
Abuse test:
Torque test: 0~18 month
2 ± 0.2 in-lbs
18 m~36 m
3 ± 0.2 in-lbs
36 m~96 m
4 ± 0.2 in-lbs
Tension test: 0~18 month
10 ± 0.5 lbs
18 m~36 m
15 ± 0.5 lbs
36 m~96 m
15 ± 0.5 lbs
Seam
15 ± 0.5 lbs
Compression test: 0~18 month
20 ± 0.5 lbs
18 m~36 m
25 ± 0.5 lbs
36 m~96 m
30 ± 0.5 lbs
Bite test:
0~18 month
25 ± 0.5 lbs
(CPSC)
18 m~36 m
50 ± 0.5 lbs
mouth contact:
100 lbs
Flexure test: 0~18 month
10 ± 0.5 lbs
18 m~36 m
15 ± 0.5 lbs
36 m~96 m
15 ± 0.5 lbs
(total: 30 cycles, 2 sec/cycle,
+/-60 degrees)
Drop test:
0~18 month
54 inch
10 times
<3 lbs
18 m~36 m
36 inch
4 times
<4 lbs
36 m~96 m
36 inch
4 times
<10 lbs
For example: under 3 years 2.5 lbs
Need do what?
10.
Sound level test:
25 cm
Handheld, tabletop, floor and crib toys----Continuous Sound Level<90 dB(A)
Close to the ear toy---- Continuous Sound Level<70 dB(A)
All toys, Impact type----Impulsive Sound<120 dB(C)
eg: Rattles
All toys, Explosive type---- Impulsive Sound<138 dB(C)
(Test Environment: at least 1m from any wall and background noise level 15 dB lower that sound being measured)
7. Battery operated toys test:
a. Check Battery Identification(battery type,voltage,orientation&polarity)
b. Possibility of charging primary battery(3 batteries and above)
c. When product is under 3 years: Batteries shall not be accessible without use a tool during normal use and after abuse.
d. Short Circuit: inadvertently or intentionally short circuit is not exhibit without using tool during normal use and after abuse
f. Leakage current test
g. Maximum voltage: 24 V DC
h. Battery surface temperature: < 71 °C
i. Single electrical circuit: Should not mix different types or capacities of battery.
11.
Cords and Elastics:
  • Cords on toys: under 18 months. Should be <12 inch long under 5 lbs
  • Self retracting cords: under 18 months.
    Should not retract more than &frac14; inch under 2 lbs.
  • Pull toys: under 3 years. If cords/elastics greater than 12 inch, can not form a loop.
发表于 2007-6-30 21:34:16 | 只看该作者
好贴,置顶!
发表于 2007-7-2 13:36:09 | 只看该作者
好啊
THIS IS A VERY VERY GOOD IDEA!
发表于 2007-8-29 15:50:50 | 只看该作者
You should say this in a guideline of on site test of ASTM
发表于 2007-9-28 09:20:28 | 只看该作者
不错啊!
发表于 2007-9-28 11:33:08 | 只看该作者
不错,顶一下.呵呵
发表于 2007-9-28 13:06:34 | 只看该作者
SUPPORT YOU! THANK YOU!
发表于 2007-9-30 11:48:38 | 只看该作者
thank you very much indeed
发表于 2007-9-30 13:59:02 | 只看该作者
thank you ,it's very useful
发表于 2007-11-5 21:45:36 | 只看该作者
you are very proficient at the toys inspection
GMT+8, 2026-11-30 13:40 , Processed in 0.037671 second(s), 19 queries , Gzip On.
