楼主: Wil
利丰集团QC报告
31#
发表于 2012-10-24 08:58:41 | 只看该作者
32#
发表于 2012-10-30 13:50:30 | 只看该作者
Inspection No.:        Client/CLT code:        Manufacturer:        MM:        Date:
                        AE/Planner:                        QC:
Inspection type:
Inspection result:
Inspection Failure Description
1
2
3
Factory Representative Signature:        Pcs defect sample sent by QC/Factory        Report to Supervisor:
        Pcs shipment sample sent by QC/Factory
Sign Off/BAT        In line        I.P. issue date        Start / End Time        Exp IC
Y / N        Y / N                /        Y / N
Product Description         P/C No.        Article N0        Client Item No.        Inspection Qty        % on Packing Line        % Packing Complete
Inspection Level                AQL
   Sample Size                                                             Pcs/sets        Max. Allowed
Defect Code        Defect Description        Critical        Functional        Major        Minor        Fu+Ma+Mi
List inspected carton numbers in space below :         Defects Found
        Total Defect Rate               %
                        AE/Planner:                        QC:
Master Carton        Size L X W X H ) cm / inch                Gross / Net
Weights (Kgs)        /
        Qty per
master carton                Barcode        Y /  N        End Carton        Y /  N
Inner Carton        Size L X W X H ) cm / inch                Gross / Net
Weights (Kgs)        /
        Qty per
inner carton                Barcode        Y /  N
Total Cartons        AQL: Major + Minor 2.5        Major + Minor        Max. Allowed        LFB QC checked carton
replacement and destruction
        # of Master/Inner Carton Defects                        Y /  N
By Products
By Material
Packing        COO Label:   Y / N           Silica Gel:   Y / N             Hangtag:   Y / N               Barcode:   Y / N            Sticker:   Y / N
        Poly bag:   Y / N        Air holes:   Y / N         Wrap:   Y / N        Taped:  Y / N         Packing:  Flatted / Stuffed / Folded
#        Test  Description        Sample        Passed        Failed        Comments
1
2
3
4
5
6
7
8
9
10
Remarks:
33#
发表于 2014-2-25 10:13:46 | 只看该作者
thanks for sharing
34#
发表于 2014-9-9 13:10:47 | 只看该作者
35#
发表于 2014-9-12 11:17:03 | 只看该作者
利丰的报告很简单的,很轻松,所以他们一天也验十多款的货,报告也就搞半小时,轻松得要命!!!
36#
发表于 2014-9-12 11:17:12 | 只看该作者
37#
发表于 2014-9-12 11:17:25 | 只看该作者
38#
发表于 2014-9-12 11:18:07 | 只看该作者
39#
发表于 2014-9-12 11:24:45 | 只看该作者
40#
发表于 2014-9-12 11:24:51 | 只看该作者
GMT+8, 2026-11-4 04:25 , Processed in 0.028118 second(s), 17 queries , Gzip On.
