查看: 4025|回复: 25
纺织品验货的详细流程(全英文),希望能给大家帮助。自己总结,无私奉献
发表于 2011-12-30 14:16:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Guide line for all softline products except fabric inspection
IPI(initial production inspection) requirement:10-20% products finished
DPI (during production inspection) requirement:30-50% products finished
FRI (final random inspection) requirement: 100% products finished and 80% were packed into cartons
If FRI shipment quantity was over +/- 5% ,
Inform clients and stand by till clients’ further instructions.
IPI,DPI :
inspection bulk size = produced qty
FRI : inspection bulk size= shipment qty
FRI selected and inspected cartons qty﹥=√shipment cartons qty (then round this number up), if the selected carton sample number could not met the requirement, select more cartons until requirement fulfilled.
Inspected sample size = L2 (details please refer to AQL table)
1, Drop carton test for crispness products
Sample size = 1 carton/carton dimension
If products were damaged or rush out of carton, take a photo, fail it and remark.
2, Assortment checking
Sample size = 3 cartons or more to cover every size & every color
If any discrepancy was found, fail and remark.
3, Barcode checking
Sample size = 3pcs/style
If any discrepancy was found, take a photo, fail it and remark.
4, Color shading/lot shading checking
Sample size = L2 (=all sample size for workmanship inspection)
If lot shading was found,
3-4 or worse than 3-4 with gray scale, fail, take a photo and seal representative shading samples for client further confirmation.
If 4 with gray scale, pending, take a photo and seal representative shading samples for client’s further indication.
If better than 4, pass
If color shading was found within same piece, take a photo and count it into workmanship (AQL).
5, Metal detection test for 0-3 year’s products
If one defect was found, fail.
6, Workmanship checking
Sample size = L2
Critical = 0
Major =2.5
Minor =4.0
Any kind of defect should be taken at least two photos, one for serious and one for slight. If result was failed due to workmanship beyond AQL, seal the major defective sample for client further confirmation.
7, Fastener reliability test for product with button, zipper, snap, stud and so on
Sample size = 5pcs / style
Open and close 3 time / PCS, if any defect was found, take a photo, fail it and remark.
8, Stuffing material screening for stuffing products:
Sample size = 1pc/style
If any defect was found,take a photo, fail it and remark.
9, Size checking:
Tolerance for garment:
Woven: under 10cm +/- 0.5cm
10-60cm  +/- 1cm
Over 60cm +2/-1cm
Knitting: under 10cm +/- 0.5cm
10-35cm     +/- 1cm
Over 35cm +2/-1cm
Special tolerance: collar, woven: +/- 0.3cm
Armhole: +/- 0.3cm
Cuff length: +/- 0.3cm
Tolerance for hometextile product:
30cm and below: +/- 1cm
Over 30cm to 60cm: +/- 2cm
Over 60cm to 200cm: +3/-2 cm
Over 200cm:  +4/-2 cm
Garment measurement: Sample size = 4pcs /size
If over 10% of total measurement points or 3pcs for same point & same size were over tolerance,fail measurement checking and sealed a defective sample for client further confirmation.
Accessory measurement: Sample size = S2
If over 10% of total measurement points were over tolerance, fail measurement checking and sealed a defective sample for client further confirmation.
10, Weighting for knitting products
For garment: sample size = 4pcs/size
For accessory: sample size =S2
(This meanings weighting sample size= measurement sample size)
If weighting discrepancy was over +/-5%, Fail weighting checking and seal a representative sample for client further confirmation.
11, Fabric weighing For T shirt
Sample size = 1 PCS /color *style
发表于 2011-12-30 15:28:28 | 只看该作者
好好学习,天天向哈,谢谢
发表于 2011-12-30 16:24:33 | 只看该作者
记号加支持!
发表于 2011-12-30 19:57:08 | 只看该作者
回复 1# myqcsister 的帖子
Thank  you very  much!!!!!!!!!
 楼主| 发表于 2011-12-31 16:40:37 | 只看该作者
原帖由 davidwjq98 于 2011-12-30 15:28 发表
好好学习,天天向哈,谢谢
相互学习,相互学习。
 楼主| 发表于 2011-12-31 16:41:10 | 只看该作者
原帖由 好好学习2 于 2011-12-30 16:24 发表
记号加支持!
谢谢支持,愿你兼职越做越好。
 楼主| 发表于 2011-12-31 16:41:39 | 只看该作者
原帖由 cunliang1213 于 2011-12-30 19:57 发表
不用客气,大家共享资源,共同进步
发表于 2012-1-11 00:22:34 | 只看该作者
Thank  you very  much for your sharing!!!!
发表于 2012-1-11 15:55:35 | 只看该作者
Thank  you very  much!!!!!!!!!!!
发表于 2012-1-19 14:29:33 | 只看该作者
good information , thanks.
GMT+8, 2026-2-4 00:06 , Processed in 0.039628 second(s), 17 queries , Gzip On.
