查看: 6372|回复: 42
工艺品 五金类 玻璃 皮革 玩具类生产流程 验货要点
发表于 2011-7-18 09:35:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
希望能帮到大家
1. ////竹等工艺品生产流程及验货要点
The Producing Procedure & QualityChecking Points-
Rattan/Willow/Fern/Grass/Bamboo
Producing Procedure
l
备料raw material incoming(防霉防虫处理/mould & insect prevention )→
l
剪料/material cutting
l
编织成型woven & formed
l
修剪trimmed
l
效果处理finish(染色dying/刷色等brushing etc )→
l
返修re-inspecting & repairing
l
烘干baking
l
装配assembly
l
包装packing
l
熏蒸fumigation(溴甲烷/24小时lasting atleast 24 hrs)→
l
出货shipment
验货要点
Quality Checking Points
l
材料的质地/色泽/粗细/the nature ,color ,dimension ofthe raw material
l
尺寸/size
l
颜色形状/color & shape
l
效果处理/finish & effect
l
湿度/humidity
l
平稳度/stability
l
刮手/splinters or sharp points
l
漏水/leakage
l
如与食品有关相关的化学药品或试剂/the relevant chemicals if
beof food
l
断裂/broken piece
l
虫眼/虫尸/生虫/worm hole/dead worm body/liveworm
2. 陶瓷工艺品生产流程及验货要点
The Producing Procedure & QualityChecking Points-Porcelain-ware
生产流程 ProducingProcedure
l
备料(陶土入厂)clay incoming
l
碎料clay mashing
l
开模(泡沫模或石膏模)molding or tooling/浇注成粗胚shaping
l
煅烧 cacline920-980℃)→
l
效果处理finish(手绘hand-painting/喷漆spraying/釉烧decal(1000-1050℃等)→
l
l
烘干baking
l
装配assembly
l
包装packing
l
出货shipment
验货要点QualityChecking Points
l
尺寸/sizes
l
颜色形状/color & shape
l
效果处理/finishing
l
重量/weight
l
平稳度/stability
l
刮手/sharp edge
l
漏水/leakage
l
裂痕/cracking
l
模线/molding mark
l
杂质/other objects
l
手印/finger mark
l
污渍/dirty mark
l
刮伤/scratching
参与人数 1金币 +5 收起 理由
hung + 5 你太有才了
 楼主| 发表于 2011-7-18 09:36:25 | 只看该作者
3. 五金工艺品生产流程及验货要点
The Producing Procedure & Quality Checking Points Hard-lines
生产流程 Producing Procedure
(冲压类/metal sheet
l
l
剪料material cutting
l
模具成型molding & shaping
l
效果处理finish(抛光polishing/喷沙sand basting/印刷printing/电镀electric-plating/喷漆spraying/喷粉coating等)→
l
返修re-inspecting repairing
l
装配assembly
l
包装packing
l
出货shipment
(铁线类/wire
l
l
剪料material cutting
l
弯型bending/焊接welding/打磨(?grilding)/成型shaping
l
效果处理finishing(喷漆spraying/喷粉coating/手绘hand-painting/电镀等electric-plating etc)→
l
返修re-inspection & repairing
l
装配assembly
l
包装packing
l
出货shipment
验货要点Quality Checking Points
l
尺寸/size
l
颜色形状/color & shape
l
l
重量/weight
l
平稳度/stability
l
沙眼/tiny hole
l
刮手/sharp point
l
功能等/function
4. 玻璃工艺品生产流程及验货要点
生产流程
l
备料/配比 raw material incoming &ratio/
l
化料/熔炉material melting
l
吹制或机压mouth blowing or machine pressing
l
冷却成粗胚cooling to be semi-products
l
火切或水切firing cutting or watering cutting
l
磨平grinding
l
cleaning
l
效果处理finish & effects (酸洗/喷沙sand blasted/烧花pattern decal/马赛克mosaic/手绘hand painted/喷漆等spraying etc)→
l
l
烘干baking
l
装配assembly
l
包装packing
l
出货(shipment)
验货要点
l
尺寸/size
l
颜色形状/color & shape
l
l
重量/weight
l
平稳度/stability
l
刮手/hand-hurting
l
漏水 /leakage
l
冰裂/crack
l
气泡/bubble
l
杂质/foreign material
l
厚度/thickness on wall & bottom
l
模印/mold mark
l
刮伤/scratch
 楼主| 发表于 2011-7-18 09:40:38 | 只看该作者
5皮革工艺品生产流程及验货要点
生产流程
l
备料raw material in coming
l
纸样paper pattern/ 剪料cutting
l
车缝/刺绣stitching or sewing or embroidery
l
打胶滚胶gluing
l
贴合成型combined & shaped
l
油边定型edge heating & formed
l
清洁cleaning
l
l
装配assembly
l
包装packing
l
出货shipment
验货要点
l
尺寸/size
l
颜色形状/color & shape
l
l
异味/odd smelling
l
平稳度/stability
l
刮手/rough edge
l
脱胶/poor or loose gluing
l
涨气/air in felt
l
刮伤/scratching
l
胶斑/glue mark
l
车线颜色及车法/thread and stitching
l
皮料(头层皮/二层皮/合成皮/pu/pvc/ material using(genuine leather/ spilit leather/ bonded leather/ pu/ pvc)
6. 玩具类工艺品生产流程及验货要点
生产流程
毛绒布料fabric or coat lines
l
备料选料raw material
l
样裁料paper pattern & cutting
l
车缝seam/刺绣embroidery/花边lace
l
填充stuffing
l
修剪trimming
l
装配assembly
l
包装packing
l
出货shipment
塑胶类plastic/vinyl lines
l
备料raw material
l
成型mold
l
效果处理(喷漆/喷粉/手绘/电镀等)(喷油/喷粉/喷沙/电镀/印刷等)Paint/satinfinished/electroplate/print
l
返修re-inspected & repair
l
装配Assembly
l
包装packing
l
出货shipment
验货要点
l
颜色形状/color & shape
l
车线车缝/thread/seam & sewing
l
异物(针头等)/foreign objects (such as needle)
l
布标/sew in label
l
拉力测试/pulling test
l
(喷油/喷粉/喷沙/电镀/印刷等)Paint/satin finished/electro-plate/print
l
5)平稳度stability: stand on the horizontal, the goods could not be incline or
l
刮手/批缝sharp edge/flash/bur
l
功能等function
l
安全测试/safety test
装饰品验货注意事项 Decoration
l
1 PICK(拔片)---材料为竹的PICK直径不得小于6MM。不能有尖头,包括插入产品内部的那端。
l
---材料为铁线的PICK的尾部必须加胶球。
l
2 类似玩具的公仔---按玩具的要求检验。
l
例如:必须要求过针机测试。
l
眼珠、针缝必须要求拉力测试。
l
毛绒类产品毛绒的拉力测试等等。
蜡烛验货注意事项 Candle
l
变形 Deformed shape
l
尺寸 Size
l
色差 Colour deviation
l
彩绘,丝印 Painting, Silk screen
彩绘的质量、颜色和位置 QualityColour & location
l
烛芯长度和粗细 Wick length & thickness
l
混杂在蜡中的脏物、异色、杂质 Dirty/Colour/Foreign material mixed inside wax
l
凹痕 Dent mark
l
破损、裂缝、缺口、刮痕 Broken/Crack/Chip/Scratch
l
香味 Fragrance
印刷品验货注意事项 Printing & Label
l
1 条形码是否正确。必须用条形码扫描仪进行扫描。扫描数量每款不得少于验货样品数量的50%且要随机抽取样本。
l
2 价格标上的英文、单价是否有错误(critical)。
l
3 检查标签的粘度是否符合要求(高、低粘度)。
l
4 纸的材质、表面的颜色。
l
5 打孔的位置,离边的距离不能太近。
l
6 折线孔的位置与折线是否一直。
l
7 检查刀线位置是否正确,及标签是否容易从整版中撕出。
LED灯验货注意事项 Light
l
1 核对产品上的CE label是否正确,如有必要要查看工厂CE label证书。
l
2 检查灯光的颜色。核对电线的颜色。
l
3 电池盒内部的金属件是否有生锈现象。连接是否牢固。
塑料盒身是否有尖点、利边。水口的修剪情况。外表面是否有 粗糙面。
l
4 电线与灯座的连接是否牢固。
l
5 深圳办公室----必须要求工厂提供该款产品的CE认证证书。
必须要求工厂提供LED灯寿命的实验报告、电线与灯座的拉力测试报告等相关工厂内部做的实验报告。
发表于 2011-7-18 10:32:38 | 只看该作者
又大又全,Really powerful,
发表于 2011-7-18 10:37:03 | 只看该作者
太给力了,
发表于 2011-7-18 11:36:39 | 只看该作者
楼主,感谢!
发表于 2011-7-18 12:51:20 | 只看该作者
感谢楼主得
发表于 2011-7-18 13:10:04 | 只看该作者
难得的好人~~~~~
发表于 2011-7-18 13:19:09 | 只看该作者
也得很好!!!!!!!!!!!!!!!!!!!!!!!!!!
发表于 2011-7-18 16:27:02 | 只看该作者
感谢楼主。。
GMT+8, 2026-6-28 16:36 , Processed in 0.038011 second(s), 19 queries , Gzip On.
