楼主: 无双
QC常用单位换算汇总
21#
发表于 2009-11-11 23:59:49 | 只看该作者
谢谢!!!学习中
22#
发表于 2009-11-12 07:22:36 | 只看该作者
我给大家公开了,免得浪费金币
单 位 换 算
一.词头(次方)
10^12 = T (TERA)    10^9 = G (GIGA)   10^6 = M (MEGA)
10^3 = K (KILO)     10^2 = H (HECTO)   10 = DA (DEKA)
10^-18 = a (arto)          10^-15 = f (feamuts)       10^-12 = p (pico)       10^-9 = n (nano)
10^-6 = u (micro)          10^-3 = m (milli)         10^-2 = c (centi)        10^-1 = d (deci)
二.单位换算
长度LENGTH
公制:mm, cm, m, km
英制:inch, feet, yard        1 km = 1000 m = 10^6 mm        1 cm = 0.394 in = 3.28 x 10^-2 ft          1条/丝=0.01mm
1 mm=100条/丝
        1 yd = 3 ft = 36 in
1 ft = 12 in        1 in = 25.4 mm = 2.54 cm
1 yd = 91.4 cm = 0.914 m
重量MASS
公制:g, kg, ton
英制:oz, lb        1 t = 1000 kg = 10^6 g
1 kg = 1000 g        1 g = 2.20 x 10^-3 lb
1 kg = 2.20 lb = 35.2 oz
1 ton = 2200 lb
        1 lb = 16 oz        1 oz = 28.3 g
1 lb = 454 g = 0.454 kg
容积VOLUME (FLUIDS)
公制: ml, l, m^3
英制:fl-oz, pt, gal        1 m^3 = 1000 l
1 l = 1000 ml        1 l = 1.76 pt = 35.20 fl-oz
1 m^3 = 220 gal = 1760 pt
        1 gal = 8 pt
1 pt = 20 fl-oz        1 fl-oz = 28.4 ml
1 gal = 4.546 l
1 pt = 568 ml = 0.568 l
温度TEMPERATURE        摄氏:℃= 5 / 9×(℉-32)        华氏:℉= 9 / 5×℃ + 32
压力(压强) PRESSURE
(P=F/A单位面积上的力)
公制:Pa, KPa, mm-Hg
英制:Psi, in-Hg …        1 Pa = 1 N / m^2
1 mm-Hg = 133.3 Pa        1 kg/cm^2 = 14.211 Psi
1 KPa = 0.145 Psi
1 mm-Hg = 1.935 x 10^-2 Psi
        1 Psi = 1 lb / in^2
1 in-Hg = 0.491 Psi        1 Psi = 6.895 KPa
1 in-Hg = 25.4 mm-Hg = 3385.82 Pa
力 FORCE
N,1kg/f,lb/f        1 kg / f = 9.81 N
1 N = 0.102 kg / f        1 lb / f = 0.454 x 9.81 = 4.454 N
1 N = 0.225 lb / f
力矩 (扭力)
(力X长度)        1 kg-m = 9.81 N-m (牛顿米)
1 N-m = 8.85 in-lb        1 in-lb = 1.152 kg-cm = 0.113 N-m
1 ft-lb = 12 in-lb
附: 集装箱货柜内部尺寸参考值: (供仿真装柜箱数换算用)
类型        限重 kgs        长=深(cm)        宽(cm)        高(cm)        一般材数CUFT        一般材数CBM
20'        18000        580        234        238        1000'        28
40'        19500        1185        234        238        2000'        56
40' HQ        19500        1185        234        270        2350'        65
45'        19500        1343        234        270        2650'        75
23#
发表于 2009-11-12 10:06:43 | 只看该作者
不错,一张表格一网打尽
24#
发表于 2009-11-17 14:39:30 | 只看该作者
我反弹出不能
25#
发表于 2009-11-20 10:15:29 | 只看该作者
下载看看,这个肯定有用
26#
发表于 2009-11-20 11:36:22 | 只看该作者
哪里下载啊·····好东西一定要收藏
27#
发表于 2009-11-21 08:54:48 | 只看该作者
好好学习下先,呵呵……
28#
发表于 2009-11-21 21:24:18 | 只看该作者
有钱就下看看
29#
发表于 2009-11-22 01:03:53 | 只看该作者
什么都没有啊
30#
发表于 2010-1-18 15:05:26 | 只看该作者
Thank you for sharing
GMT+8, 2026-9-13 10:58 , Processed in 0.065987 second(s), 17 queries , Gzip On.
