查看: 2584|回复: 8
眼镜架及镜片的相关标准
发表于 2009-1-14 10:46:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
眼镜架及镜片的相关标准(ISO12870&BS6625-1&镍释放量)SPECTACLE FRAME TESTS
1.        BS EN ISO 12870:2004-Soectacle frame test
a.        Dimensional tolerance 尺寸大小
b.        Dimensional stability at elevated temperature 升温后尺寸大小稳定
c.        Bridge deformation 桥位变形
d.        Lens retention 镜片保持力
e.        Endurance 柄
f.        Resistance to perspiration 抗汗
g.        Resistance to optical radiation 抗紫外线
h.        Resistance to ignition 抗燃烧
i.        Tolerance on screw thread 螺纹公差
j.        Nickel release 镍释放量
k.        All of the above 全套测试
2.        BS 6625-1
e.        Endurance 柄
i.        All of the above 全套测试
3.        Nickel release 镍释放量
a.        Cotton ball test according to 76/769/EEC(EU Directive 94/27/EC)
b.        BS EN 1811:1999
Body-piercing post assemblies(e.g. pin of earring 耳针)
(EU directive 2004/96/EC)
c.        BS EN 1811:1999
Reference test method for release of nickel from products intended to
come into direct and prolonged contact with the skin
d.        ENV 14027:2001 and BS EN 1811:1999
Method for the simulation of wear before the detection of nickel release
from coated metal and combination spectacle frames
e.        BS EN 12472:1999 and BS EN 1811:1999
Method for the simulation of wear and corrosion for the detection of
nickel release from the coated items
4.        Eye Glasses
a.        Impact Resistance/Drop Ball Test-US ASTM F 963(per lens)
                                         -US FDA(per 6 pairs)
b.  Luminous Transmittance and lens category-Australia AS 1067 part 1:1990
                                               -Europe EN 1836:1997
                                               -US ANSI Z80.3-1996
c.  UV(UVA&UVB) Transmittance
发表于 2009-1-14 12:08:04 | 只看该作者
Thank you very much. lz
发表于 2009-1-20 21:36:32 | 只看该作者
怎么没有标准附件?
发表于 2009-3-20 21:32:17 | 只看该作者
thank you very much!
发表于 2010-1-4 11:46:30 | 只看该作者
标准找不到,
发表于 2011-7-7 00:25:23 | 只看该作者
先谢谢了。。
发表于 2014-3-20 20:31:41 | 只看该作者
thank for sharing
发表于 2014-6-8 18:50:53 | 只看该作者
果断收藏~
发表于 2014-6-8 18:51:35 | 只看该作者
果断收藏~
GMT+8, 2026-11-30 12:04 , Processed in 0.026690 second(s), 17 queries , Gzip On.
