123
返回列表 发新帖
楼主: 純爺們→軍
充气类产品FLOAT PRODUCTS检验大体标准 免费送
21#
发表于 2008-11-14 15:40:22 | 只看该作者
我公司是这样的,
4.1 Performance Tests
   4.1.1 Mattress Pressure / Leak Test: (Inflatable Bed)
  The mattress will be fully inflated to a pressure of 12.9 mm Hg (6.9 in H2O). A sheet of 1.2 m x 45.7 cm x 1.9 cm (4.0 ft x 1.5 ft x 0.75 in) board will be centered on the mattress. Three (3) 22.7 kg (50 lb) weights will be distributed on the board.
After 24 hours, the mattress pressure will be no less than 5.2 mm Hg (2.8 in H2O).
   4.1.2 Weld Failure Test: (Inflatable Bed)
  The mattress will be inflated to a pressure of no less than 67 mm Hg (36 in H2O) without weld or valve failure.
   4.1.3 Static Load Test (Twin): (Inflatable Bed)
  Inflate each chamber of the mattress to a pressure of 15 in H2O. A sheet of 1.2 m x 45.7 cm x 1.9 cm (4.0 ft x 1.5 ft x 0.75 in) board will be centered on the mattress. Weight totalling 147.4 kg (325 lb) will be distributed on the board.
After 1 hour, there will be no leaks.
   4.1.4 Set A Load Test (Twin): (Inflatable Bed)
A sheet of 1.2 m x 45.7 cm x 1.9 cm (4.0 ft x 1.5 ft x 0.75 in) board will be centered on the mattress. Weight totalling 147.4 kg (325 lb) will be distributed on the board. Suspend the weighted board 2.5 cm (1 in) above the mattress.
The weighted board will be dropped onto the mattress 4500 times at an appropriate rate of between 5 and 40 cycles per minute constantly maintaining 2.5 cm (1.0 in) above the mattress.
At end of test, there will be no leaks.
   4.1.5 Drop Test w/ Weight (Twin): (Inflatable Bed)
A sheet of 1.2 m x 45.7 cm x 1.9 cm (4.0 ft x 1.5 ft x 0.75 in) board will be centered on the mattress. Weight totalling 147.4 kg (325 lb) will be distributed on the board. Suspend the weighted board 15.2 cm (6 in) above the mattress.
The weighted board will be dropped onto the mattress 6 times constantly maintaining 15.2 cm (6.0 in) above the mattress.
22#
发表于 2008-11-14 18:46:19 | 只看该作者
好东西,顶下
23#
发表于 2010-4-20 13:03:58 | 只看该作者
请问这位高手像充气的球类该怎么测试和检验足球?
能否发一份给alanjiang_8888@126.com感激不尽。
24#
发表于 2010-4-20 21:53:01 | 只看该作者
好东西,学习了
25#
发表于 2010-4-27 10:30:14 | 只看该作者
学习一下,世界太大,我等要多多学习啊
GMT+8, 2026-11-30 15:38 , Processed in 0.027300 second(s), 16 queries , Gzip On.
