查看: 975|回复: 4
QC鞋类英语短语、句子-干货
发表于 2017-8-17 09:45:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
QC鞋类英语短语、句子-干货
一.港宝瑕疵(COUNTER   DEFECTS)
1.Counter   sheet   not   lasted   under   insole(港宝没有拉邦至中底之下)
2.Wrinkled   counter   caused   either   by   poor   lasting   or   by   wrinkled   chemical
        sheet(拉邦不良或港宝片皱折造成后套皱折)
3.Soft   chemical   sheet   due   to   wrong   materials   or   wrong   primer
    (港宝片品质不良或处理不良以致港宝太软)
4.Crooked   chemical   sheet(港宝位置歪斜)
5.Low   positioned   chemical   sheet(港宝位置过低)
6.Blisters   on   counter(后套部位有气泡现象)
7.Back   height   not   uniform   within   pair   by   2   mm   or   more
        (后套高度不一致达2mm   或超过更多)
8.Other   counter   defects   (其他港宝瑕疵)
二.Crooked   Upper   Defects   (鞋面弯斜瑕疵)
1.Topline   crooked   or   wavy(鞋领口歪曲或成波浪状)
2.Back   seam   off   center,   twisted     or   not   vertical   to   heel   seat,   by   2mm
    (后合缝车线不正,偏离中线、扭曲或没与后跟垂直----偏离达2mm。)
3.Back   heights   not   uniform   within   pair   (左脚后套高度不一致)
4.Different   vamp   length   of   left   and   right   foot   over   2   mm
      (左脚鞋面长度不同,相差超过2mm。)
5.other   crooked   upper   defect   (其他鞋面弯斜瑕疵)
三.Color   Variation   defect(色差瑕疵)
1.Poor   antique   treatment     (   锈色处理不良   )
2.Color   variation   between   different   piece   of   upper(鞋面不同部位的色差)
3.Color   of   stitching   and   upper   material   not   matching   (as   per   confirmation
        sample)     车线材料与鞋面材料颜色不对(参照确认样品)
4.Wrong   color   on   ornaments   and   lace(装饰物与鞋带色差)
5.Variation   between   left   and   right   shoes(左右脚色差)
6.Poor   printing   and   embroidery(鞋面不良印刷或刺绣)
7.Contrast   color   of   PU   coating   and   back   fabric(PU面及布里成对比色)
8.Other   color   variation   defects(其它色差瑕疵)
四.Damaged   Upper   Defects(鞋面破损瑕疵)
1.Scratch   mark   on   upper   (鞋面擦痕)
2.Visible   roughing   marks   more   than   1.5mm   or   conspicuous                                          (看得见的磨粗过高,超过1.5MM   或很显眼.)
3.Cut   upper   (鞋面破裂)
4.Torn   upper   caused   either   by   high   stitch   density   or   poor   reinforcement.
    (因不良补强或车线针距太密造成的鞋面破裂)
5.Poor   heat   embossing.   (高温后压花不良)
6.Toe   box   collapsing(鞋头下陷)
7.Missing   or   incorrect   material   embossment(材料压纹消失或不正确)
8.Loose   or   missing   ornament   parts.(装饰配件丢失或松动)
9.Broken   strap(前带或后带断裂)
10.Other   damaged   upper   defeats.(其它的鞋面破损瑕疵)
五.Eyelet   and   lace   defects(鞋眼和鞋带瑕疵)
1.Punched   hole   bigger   or   smaller   than   eyelet.(鞋眼与打洞不合)
2.Poor   eyelet   attachment.   (鞋眼钉合不良)
3.Loose   eyelet.   (鞋眼松落)
4.Paint   coat   peeling   off.   (鞋眼的漆层剥落)
5.Rust   eyelet   or   other   mental   buckles.   (鞋眼或其它的金属扣生锈)
6.Wrong   length.   (错误的长度)
7.Wrong   color   、wrong   material   or   wrong   type   of   lace.(鞋带颜色、材质、型式不对)
8.Broken   yam(断纱)
9.Eyelet   row   not   uniform   by   2.4mm.(鞋眼排列不整齐,偏离达2.4mm)
10.Dirty   marks   on   lace.(鞋带有不良记号)
11.Shoelaces   tied   together.   (左右脚鞋带系在一起)
12.Other   eyelet   and   lace   defects.   (其它的鞋带和鞋眼瑕疵)
六.Lining   Defects   (includes   vamp、sock   and   counter   lining)
    (内里瑕疵,包括鞋面、鞋垫、后套里)
1.Lining   dirty   or   damaged   or   wrinkled   (内里不洁、破损或皱折.)
2.Trimming   damage   on   topline   stitching,   causing   lining   to   show   gap
      (修内里口造成的破损导致开口。)
3.   Sock   lining   gap   not   deeper   than   2mm.
鞋垫里位置歪斜达2   mm或超过(鞋垫贴合不良)。
4.Cementing   off,   between   upper   and   lining       (鞋面与内里贴合不良。)
5.Poor   or   unclear   marking     (不良或不清楚的标记。)
6.   Other   lining   defects   (其它内里瑕疵)
七.Stitching     Defect(针车车线瑕疵)
1.Crooked   stitching   (out   of   stitching   mark)车线歪斜(偏离记号点)
2.Stitching   too   close   to   seam   edge   (针车太靠近边距)
3.High,   low   or   uneven   stitch   density   (针距太密,太松或不平均)
4.Loose   or   tight   stitching   (车线太松或太紧)
5.Skipped   stitch   on   upper   (跳针)
6.Incorrect   needle   type   (不适用的针型)
7.Incorrect   thread   size   (线的粗细不对)
8.Open   seam   (车线接合裂开)
9.Thread   end   (线尾未修剪干净)
10.Other   stitching   defects
(其它针车线瑕疵)
八.Upper   dirty(鞋面不洁)
1.Glue   stain   (贴标痕迹)
2.Dirty   marks   (不洁的记号)
3.High   glue   line   more   than   1.5mm   in   any   area
(胶线太高——于任何部位超过1.5CM)
4.Frayed   edge   of     PVC   upper   material   (PV/PVC   鞋面材料毛边
5.Mold   or   mildew     发霉
6.Other   upper   dirty   defects(其它鞋面不洁瑕疵)
九.Wrinkled   upper   defects(鞋面皱折瑕疵)
1.Wrinkles   caused   by   poor   lasting   (拉邦不良造成的皱折)
2.Wrinkles   caused   by   poor   bottoming(贴底不良造成的皱折)
3.Wrinkles   caused   by   distorted   upper(鞋面变形造成的皱折)
十.X-ray   Defects(X-RAY瑕疵)
1.X-ray   lines   on   any   part   of   upper   showing   through   due   to   edge   folding,   chemical   sheet,   toe   cap   ,etc
(由于拗边,港宝片、鞋头包片等引起的任何鞋面部位的透痕)
2.X-ray   lines   of   upper   lasting   allowance   showing   through   on   bottom   due   to   improper   buffing   or   filler
(大底贴邦部位不平顺有X-ray产生,由于磨粗不平或填腹不良引起)
十一.Sole   Bottom   Dirty   Defects(大底不洁瑕疵)
1.dirty   marks   (不洁记号)
2.poor   outsole   printing   or   paint   peels   off   (大底印刷不良或上漆剥落)
3.Rough   edge   of   EVA   outsole     (EVA底边未磨匀)
4.Impurities   in   sole   material   (大底物料不纯)
5.Other   Bottom   dirty   defects(其它大底不洁瑕疵)
【核心提示】鞋类英文--QC验鞋术语QC的工作:通常要与客户沟通联络,负责鞋样板、大货生产质检全过程;与跟单配合反馈质检工作;汇报质检结果
      鞋界QC的工作:通常要与客户沟通联络,负责鞋样板、大货生产质检全过程;与跟单配合反馈质检工作;汇报质检结果,向主管提交报告,针对存在的问题提出改善建议,要用到的一些常用词汇.
Wrapping   not   even攀帮不均匀
Shank   too   loose铁心太松
Heel   not   straight后套不正
Sole   come   off底脱胶
Wrong   pattern   纸板错误
Wrong   material材料错误
Wrong   cutting裁断错误
Toe   broken   down鞋头凹陷
Color   variation色差
Wrong   last   楦头错误
Wrong   colour颜色错误
Damaged   upper鞋面破损
Not   in   pair不配双
Crooked   back   stay   后套歪斜
Crooked   upper鞋面弯曲
Crooked屈曲,不平顺
Vamp   length鞋头大小
Lasting   off   center攀歪
Sole   laying   not   proper(centered)贴底不正确
Back   strap   too   high(low,long,short)后拉带太高
Abrasion磨损
Stitching   not   on   the   mark不照记号齿车
Angle   on   insole中底发角
Vamp   open   up鞋面掀开
Wrapping   not   tight攀帮不紧
Shank   not   straight铁心不正
Cementing   comes   off脱胶
Outsole   not   smooth大底不平
Gore   too   weak松紧带弹性不佳
Cement   on   heel鞋眼沾胶
Cementing   no   good接着力不佳
Cleanness   not   enough清洁度不佳
Vamp   split   off   鞋面爆开
Color   not   matching色差
Loose   thread脱线
Broken   thread断线
Trun   yellow变黄
Turn   dark变黑
Pinch   in   缩进去
Flatten变平
Rough粗糙
x-ray透痕
smeary污染
hairy   起毛
gaping   缝隙
sole   adhesion大底欠胶
chip碎屑
dirty   脏的
get   mildew发霉
back   height   后跟高度
over   cemented溢胶
bottom   dirty大底不洁
wet   operation   湿场作业
trimming   and   sorting   削整及分皮
soaking   浸水
fleshing   削肉
unhairing   脱毛
bating   酵解软化
picking   浸酸
tanning   鞣制
wringing   挤水
splitting   and   shaving   起层及削里
retanning,   coloring   再鞣,染色
setting   out   张皮
dry   operation   干场作业
drying   干燥
conditioning   回湿
staking   铲软
buffing   磨皮
finshing   整饰
measuring   量皮
grading   分级
发表于 2017-9-18 12:54:54 | 只看该作者
深圳市亚海产品质量检验有限公司 简称ASI,是一家专业的第三方检验公司,公司拥有一支十多年专业的检验团队。可提供全国各行各业的产品检验,工厂审核、监柜监装等服务。专业的服务,合理的价格,可先验货后付款。  欢迎来电咨询:联系人:Frank 袁先生  手机13640934726  QQ:727203880
E-mail: 727203880@qq.com
www.asiaseainspection.com
您好:请多关照!我是验货员Frank,本人有通行证可以去香港澳门台湾做验货跟单。假如有验货公司或外贸公司或老板们有需要的可以联系;我常住在广东深圳,承接广东及福建范围内验货验厂监柜。十五年工作经验全能型验货员,诚信为本请多关照!联系方式:Frank / 袁先生13640934726,QQ:727203880(可以全国大部分地市提供验货服务)。多谢关照!
本人专注品质15年,同时具有生产工厂的品质管控,外贸公司业务跟单及质量控制和检验,第三方公司产品质量检验之工作经验。目前全兼职常住深圳提供验货验厂监柜服务于深莞惠及广东福建周边范围。
自备有:笔记本电脑,相机,潘通色卡,克重称,湿度计,电子卡尺,条码扫描仪, 卷尺,3M测试胶带,专用封板贴纸+封箱胶带,返工贴纸,工具包,等常用工具。承接:服装,鞋子,玩具,陶瓷,树脂,铁艺,箱包,杂货,工艺品,家具(桌椅柜等板式,休闲家具,室内和户外,办公和民用,高光亮等家具),各类工具(电动,手动),提供验货(首件,中期,尾期),验厂和监柜服务。
可以检验一般超市类消费产品且在验货当天出具详细英文报告,格式按照几大公证行的报告格式或指定模板格式。不擅长的有:军工产品,航空航天产品,医药产品(一般民用商品都可以检验)。
本人工作态度严谨,为人诚实守信,期待与每个客户建立长期合作关系。
深圳市亚海产品质量检验有限公司  提供大中华区验货验厂测试服务。
联系方式:QQ:727203880,电话13640934726袁先生/Frank, 多谢关照。
参与人数 1金币 -20 威望 -40 收起 理由
hung -20 -40 多次文不對題的回復!
发表于 2018-1-22 21:22:47 | 只看该作者
不错的,学习一下
发表于 2018-2-24 18:06:12 | 只看该作者
我只想知道九个款,十一点五十开始验要多久验完
发表于 2023-4-27 10:01:21 | 只看该作者
:lol
GMT+8, 2026-2-4 00:06 , Processed in 0.049370 second(s), 18 queries , Gzip On.
